John Deere 410C QUESTIONS!!!
/ John Deere 410C QUESTIONS!!! #1
Nicetoy
Member
Connecticut
1986 Ford 1710, JD 410C, and JD 450
Hello All,
A couple weeks ago I found a deal I couldn't pass up on a 88' Deere 410C. Machine runs mint and had a new factory engine installed about 1000 hours ago. Hydraulic pump was also replaced within the last 1500 hours. So, there is the good, now the bad. Machine has been neglected and not used for a few years, doesn't look like it was greased very often, and pins/bushings in the hoe are SHOT. It is very loosey goosey and has a crack at the top of the dipper stick. The crack should be easy enough to weld up, and looks like stress from the bucket cylinder was the culprit there. The biggest problem however is the bushings/pins attaching the swing tower to the frame. The bushings are so bad, that there is nothing left and it's riding directly on the frame. Any thoughts? Advice?
Background:
My wife and I just bought 20 acres and are going to be building in the spring. This was bought to assist in sitework and the whole construction process as a way to offset costs. After building is done, I plan on keeping it around as a homeowner machine to work on various projects and clear snow (650ft driveway). Everything on the machine is in decent shape, and it runs great. It is typically a 12-15k machine and I paid 5K for it, so i don't think I can get hurt on it.
Does anybody own one of these machines that can tell me their experiences with them? There doesn't seem to be much info out there, and parts seem a bit difficult to source. Also, if anybody owns one, could somebody take some detailed pictures of the swing tower to frame connections so I can compare since mine is a mess.
Thanks In Advance
/ John Deere 410C QUESTIONS!!! #2
The parts should be readily available through Deere.
I was more referring to the aftermarket parts world.. factory parts are just so damned expensive
/ John Deere 410C QUESTIONS!!! #4
Try heavyquip.com for aftermarket parts.
/ John Deere 410C QUESTIONS!!! #5
Ok I misunderstood what you were gettin at. I agree that Heavyquip would be a great place for after aftermarket parts.
Are the pins and bushings in your boom the parts that are worn out?
yes, the loader is pretty worn too, but usable as is... The worst is the frame to swing tower pins/bushings
/ John Deere 410C QUESTIONS!!! #7
UPDATE!!!! With Pics! Here is the Frame to upper swing tower mount after I got it all apart. Talk about ugly! Old Frame mount.jpg
Re: John Deere 410C QUESTIONS!!! * Updated w/ Pics
The frame was so bad, I didn't have many options. I found a Parts machine, and bought the Swing Tower/ Boom/ and Dipper from it. The guy also cut off that upper Frame to Swing mount for me, and I had to call in my mobile Fab guy!. Shown is the old mount/swing, and new ones.
New Frame mount welded on with new bushings.
Welded on a 32" Thumb.
Used my Trusty 1710 to carefully get the new boom, and Dipper Pinned on.
My house project got delayed as did this. But now I'm almost there. Tree work on my property is done with about 2 1/2 acres clear cut. Just finishing up this Hoe so I can get out there and rip my stumps out..
Also added a new toy to the stable!
/ John Deere 410C QUESTIONS!!! #15
Now that is wore out!
/ John Deere 410C QUESTIONS!!! #16
UPDATE!!!! With Pics! Here is the Frame to upper swing tower mount after I got it all apart. Talk about ugly!View attachment 325566
Fwiw and consideration for next time in similar applications. there is Chockfast Orange. It could have saved you a lot of time amd sweat. Simply mix and pour in-situ. This is used in ships rudder post bearings that take a worse beating than any excavator or backhoe could ever imagine.
ITW Chockfast Marine | Epoxy Grouts, Adhesives, Repair Products, Coatings
Interesting thought... Have you ever used it? Luckily I was able to find a local parts machine that was in reasonable condition, and cut off that mount from the parts machine, and the mount from my machine and welded on the new one. That's what I love about forums, its the cross technical knowledge. Some stuff works, and some doesn't BUT thats all worthwhile knowledge.
/ John Deere 410C QUESTIONS!!! #19
That has to be the worst bearing mount I have ever seen that remained intact. Yes, I have used Chockfast in the same and similar applications, plus chocking heavy marine diesels, reduction gears, shaft bearing mounts, and skeg rudder bearings. It is far cheaper and faster than milling steel shim parts, and withstands enormous forces and vibrations. There are also several brands on the market that would also be suitable such as Devcon | acrylic, acrylic adhesive, adhesive, adhesive and sealants, adhesive applicator
One of Chockfast's claims to fame was that it was used extensively in the re-powering of the QE2: The Repowering Of QE2
All back together and working nicely! A little slop, but definitly homeowner worthy. The swing to boom pins still need to be replaced, that should tighten it up a bit.
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
Wooden Rocking Horse (A61569)
Wooden Rocking...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 84"...
FUTURE SZYMJ HYD MINI STUMP GRINDER (A62130)
FUTURE SZYMJ HYD...
Paladin Dirt Sifter (A61166)
Paladin Dirt...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2006 Ford F-350...
