John Deere 401C Hydro trouble
   / John Deere 401C Hydro trouble #31
Finally got the pressure gauge on via PS line and only have around 300 psi. I will check the flow from the transmission pump next, with time slots in my schedule. Can I remove the pressure control valve without 10 gallons seeking ground? Is it only the drain plugs which will pour out the contents of the sump or is there others I should be aware of?
Yes, you will lose some oil, but 10 gallons. You could drop the transmission filter and put a 5 gallon bucket below the opening. The transmission pump, pumps to the transmission filter first. Be aware, only run the engine a few SECONDS! If the transmission pump works as it should flow is about 6 gallons, per minute. You will fill the 5 gallon bucket in less than one minute.
I didn't test the flow from the transmission pump as time was against me as Fall as arrived and will be cold soon. How does the pressure relief valve come out? You would figure it to be somewhat under spring pressure as the cap is tightened but it's not the case here! Can it be seized in the housing?
I am not familiar with the Industrial Deeres, on the AG version a sleeve comes out with a spool and spring inside between two roll pins. Parts drawing show an exploded view. Drawing is 2030AG, NOT yours
   / John Deere 401C Hydro trouble #32
My pressure relief valve is in the exact spot on the transmission as shown in your pic. It should be loose in there or am I overlooking on how it comes out? I do see the rolled pins inside, are they there to hold the assembly together as one part?
   / John Deere 401C Hydro trouble #33
Yes, it should be loose enough to slide right out. The roll pins hold internal parts (spring and spool) in body (at least that's how AG tractors are. Over pressure causes the spool to compress the spring and open a passage back to sump.
   / John Deere 401C Hydro trouble #34
I've tried using a punch with no success :( It's stuck in there, now what do I do? I'm able to turn the roll pins with needle pliers but that's about it!
   / John Deere 401C Hydro trouble #35
OK, I got it out after cluing there wasn't a spring behind it. I didn't take it apart but I made sure everything was loose in it! Maybe I should of taken it apart and inspect for wear, next time. I observed a pressure of 2000psi temporary until I I tried to lift the bucket. The pressure has been fluctuating and the FEL along with the PS are slow to react, could be the RPM's are on the low side. Somewhat encouraged and will top up the tranny and see if that helps any. Now I need to find a favorable spot to install the pressure gauge permanently. Tried using the small screw on the main pump but cannot find a suitable adapter fitting.
   / John Deere 401C Hydro trouble #36
Here's a fitting that will fit in frt RH side of pump that will require a coupler that JD dealer can order. Have you investigated a good hyd supply/repair business for a fitting?
   / John Deere 401C Hydro trouble #37
I think you should change your avatar name to "Thx Jim" :) You've been very helpful as always :thumbsup:
I will contact my dealer for the adapter as my neighbor's hydraulic shop couldn't match the thread size on your previous post.
   / John Deere 401C Hydro trouble #38
Seriously I've considered changing my handle to Jim in Tx. Looking up information helps keep my old brain functioning!!!
   / John Deere 401C Hydro trouble #39
I pinpoint the culprit of my FEL and steering woes on the Pressure Control Valve. Local dealer is unable to get one or kit and says they're discountinued. Any other source to find one. What's the correct part #? I could fabricate another style into the system by blocking off the transmission two holes with a plate and maybe using one hole for return of over pressure.https://www.tractorbynet.com/forums/asset.php?fid=584263&uid=344904&d=1603539926
   / John Deere 401C Hydro trouble #40
What parts do you need for it? Looking an JD parts, parts appear to be available, most are O-rings, fittings, the internal valve and spring are available. If the housing is OK, you should be able to get any internal part. The housing is BIG money, but available too. $1625
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
Show Livestock Tie Up Rack (A50515)
Show Livestock Tie...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
