john deere 3520 wont start.
/ john deere 3520 wont start. #1
burnpile
john deere 3520
I tried to start the tractor yesterday, when you turn the key usually the dash lights come on, then turning further starts the engine. Now when I turn the key everything is dark, I charged the battery overnight so its good. When the key is on if I turn the headlight switch the dash lights flicker, but then go dark.
I hooked my jump starter battery directly to the battery terminals and the dash doesn't light up like it did before. Usually the glow plug indicator is light and the gauges go to the max then back to 0. If I turn the headlight switch the dash lights for a second and then goes black. The hazard lights and headlights work.
/ john deere 3520 wont start. #4
You need to remove, clean, and re install all four battery cable connections. Problem could be any one (or more) of them.
I did clean the terminals at the battery, I see where the ground connects to the frame, I guess the positive is connected to the starter?
I did that, but there is no change, I also pulled the fuses and cleaned the terminals, there are 5 of the small 2 blade ones and three that are about 1" sq with multiple terminals.
Seems like something to do with the light switch since when I turn it lights intermittently flash on the dash, not sure why this switch would control the tractor starting.
/ john deere 3520 wont start. #9
Did you ohm all the cables?? The can be open
and you will not be able to see the break with
the coating on the wire
willy
/ john deere 3520 wont start. #11
I’m going to guess it’s something other than the battery but I’d pull it out and load test it to make 100% sure. Charging it and checking the voltage is not enough, it needs load tested.
Wouldn't using the jump battery eliminate the possibility that the battery was the problem? I started taking the plastic covers off around the steering wheel and gauge panel, I'll get a pic when I get them off, from what I can see there is a ton of dirt/grass covering everything under them.
I'm going to buy a new battery and see if that helps, I just checked the voltage on the existing and it only 12.7 v.
/ john deere 3520 wont start. #15
The battery can have voltage but no amps that's
why Dodge man said load test it to make sure the
battery is good.
willy
Took it out tonight, its 8 years old, seems like its not been long since I remember putting it in but I cant be 8 years older....
/ john deere 3520 wont start. #17
LOL!
Time flies when you are having fun!
Maybe the battery was 5 years old when you put it in! That would account for its age, lol!
David from jax
/ john deere 3520 wont start. #18
You can always check the voltage while the lights are on and trying to crank, that will sometimes show a large voltage drop indicating a bad battery,
These are also handy to have around for the price:
I'm going to get one, takes the guessing out of battery health. The new battery will be at my shop today so hopefully that does solve the problem.
I guess its a process of elimination, new battery has the same symptoms. Must be a wire that is shorted or something. I'll continue taking the plastic off, I think I need to remove the steering wheel and the nut that holds the ignition switch in place, have all other fasteners out that I can see. Going to Lake Tahoe for the weekend so nothing will get done until I get back most likely.
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A68842)
TIRE RACK WITH...
10ft Fork Extensions (A66734)
10ft Fork...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
