John Deere 336 with #30 Bale Ejector Problem
/ John Deere 336 with #30 Bale Ejector Problem #1
sgm98z
Orrstown, PA
Massey Ferguson 255
I have a Massey 255 and a John Deere 336 with a #30 bale ejector.
The Massey has a set of remotes that are normally used for the FEL which works fine.
When I hook up the baler to the remotes I can only get the ejector to turn in one direction. In order to get it to turn the other way I have to reverse the hydraulic lines. I'm wondering if this is a problem with the baler or the tractor?
The reason I'm confused is that the FEL works just fine when connected to the remotes.
Any ideas how to isolate the issue?
/ John Deere 336 with #30 Bale Ejector Problem #2
Does the FEL have its own control valve.... I expect so.
Some rear remotes are intended for double acting cylinders and either half of the remote can become an IN or an OUT port.
I do not know your tractor and what control you have over the rear remotes.
It may be that if you cannot change your remote's IN and OUT, that you need a double acting valve in order to control the baler.
Then the hook up will be like your loader.
Dave M7040
Dave M7040
Dave, thanks for the reply. I think you may have nailed it. The FEL does have it's own control valve. I didn't think of that. I'll look into the double acting valve and see if that remedies the issue. Thanks again, Mark
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
Kinze Planter Tire (A65640)
Kinze Planter Tire...
1983 Chevrolet C70 Flat Bed Dump (A62613)
1983 Chevrolet C70...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
