John Deere 3320 Hyd. problem.
/ John Deere 3320 Hyd. problem. #1
491ton
Milton, Iowa
John Deere 3320 cab tractor
I think that there is air in my hydraulic system. Can an owner bleed this out himself at home? Thanks, Terry
/ John Deere 3320 Hyd. problem. #2
1st off, what makes you think you have air in the system? Have you opened the system for any repairs or replaced lines?
2nd, the best way I know of is to open a line part way at the component in question and actuate that component until a steady stream comes out. Usually a hydraulic system does't need bled and will come back with simply using it. What issues are you having?
The problem is a whining screaching noise in the sys. If I lower the RPM it goes away.
I added a doubler, And opened the lines to do this.
/ John Deere 3320 Hyd. problem. #6
Doubler? What is that exactly? Opened what lines?
A doubler is a hydraulic splitter to add a third hyd. circuit.
/ John Deere 3320 Hyd. problem. #8
did it lower your pressure too much? robbing pressure from the main circuits?
/ John Deere 3320 Hyd. problem. #9
Ah so a diverter valve, what lines did you open? They are generally plumbed after the remotes, so not sure how that would Introduce much air, and as stated the system is self purging. Did this start after the diverter install?
If you want some help then please offer some specifics...
/ John Deere 3320 Hyd. problem. #10
I have also seen low fluid cause some similar concerns.
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
