John Deere 318 voltage regulator
   / John Deere 318 voltage regulator
Do you have a pic of the old regulator? Not sure I've seen one different than this type.
I do have a picture, but I can't figure out how to add a photo from my phone. I'd have to wait until I'm at work to use the computer.
   / John Deere 318 voltage regulator #32
When I was a kid 15+ years ago my dad bought a battery for his mower and he had to add the acid, I haven't seen one since.
Thanks for the correction, I personally have never dealt with one but have seen one or two my dad bought.
No Problem.
I just don't want anyone accidentally deciding to add acid when all they should be adding to low battery cells is water.
I used to do what you mentioned above, years ago; but I think they did away with that for safety issues and now all batteries are already filled with acid/water mix at the factory and are called wet batteries.
It's a bad picture. But those are the connectors. One is undone as I took this picture when I was taking the connections off while doing a valve adjustment.
   / John Deere 318 voltage regulator #34
Great, thanks. I'm getting a multimeter today. So test it before starting, then fire it up and test it at WOT? Or should it be at a different throttle range? I really don't want an explosive issue haha.
For point of info, the voltage mostly stays the same regardless of throttle position. The only time it varies greatly is when a 'load' like headlights are being used and the battery would be 'drawn' down if the voltage regulator didn't compensate for the draw down.
Batteries do best from 100% state of charge to about 80% and then back to 100%, supplied by a properly functioning charging system.
Otherwise the battery life is shortened by being allowed to undercharge, say down to 60% then back to 100.
Cold and hot temps wear harder on batteries than do relatively moderate ambient temps. That's why auto charging systems fail/ batteries die in very hot weather or extreme cold. CCA, Cold Cranking Amps is one thing used to determine the appropriate battery for a particular engine/use. Air conditioning and heater fans in winter months draw a lot of amps, which is flow of current through a circuit. Current is literally heat transfer through wires to an output/use, heater fan moving heat to warm a vehicle. Headlights draw lots of amps - heat out of the lamp = energy consumed from the battery. That energy is restored by the engine burning gas/diesel, to resupply energy lost from the battery, (discharging to say 75% state of charge), then being charged back to 100%.
This ongoing CE course is only $500/week. I take Visa and MC! :thumbsup::laughing:
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
Portable Restroom (A54865)
Portable Restroom...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
2004 JOHNSTON STREET SWEEPER (A58017)
2004 JOHNSTON...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
