John Deere 318 voltage regulator
   / John Deere 318 voltage regulator #21
There isn't an automotive style alternator on a mower like this. They run permanent magnets inside the flywheel and have a stator mounted stationary to the back of the engine that sits inside the flywheel. From there the rotating flywheel magnets cause the stator to output AC to the rectifier/regulator which is usually mounted on the flywheel shroud with fins inside the shroud which get cooled by air coming off the flywheel. 3 wire plug on the regulator. You could also measure voltage right there instead of getting close to the battery. From memory it's the center terminal on the plug, should be 14 ish running (red wire on your meter, black wire goes to chassis ground). The outer two terminals should be around 26 volts AC coming from the stator at full throttle. Maybe 28. It's been years since I've checked one.
You're welcome.
I would go about it differently, BUT I completely understand your concerns.
So first disconnect the ground, (minus/negative) battery cable, usually black color sheathing. Set it aside.
Then positive cable, (red), without allowing the wrench to come in contact with any metal part of the mower.
Then replace your ignition switch, AFTER taking a few pics of what goes where, wires, etc. Draw yourself a diagram if necessary.
Replace the switch with the new one. Same procedure with the new voltage regulator, pics, then remove and replace.
Now install the new battery, after making sure there are no remaining frayed, broken, loose or otherwise not secure wires anywhere on the machine.
Recheck to make sure the neg and pos cables to the battery are in the right place.
You should be able to start it and verify the output voltage as detailed earlier.
Now, if it doesn't start, there can be other reasons, which get more complicated, so lets get this far before going deeper.
You should gather the year and exact model of the mower, the serial number and what EXACT engine it has in it. These items tell the tale of what parts may be needed to make it run/run properly. There are numerous issues with these mowers, especially if the engine was ever swapped out, if a different ignition switch was installed, etc. So get all the data you can so you can post it here if we determine further investigation is needed.
Take your time, check everything overe, and don't panic; it's not rocket science, yet!:eek:
So I did the test. I bought a new battery just for my own peace of mind. I tested the battery before putting it in the tractor and it was 12.55.
I fired up the tractor at a little less than half throttle and tested it while I was waiting for it to warm up. It tested at 16.23. I panicked (haha) and just shut it down. I never got it to full throttle. I'm assuming that if it is testing at 16 at half throttle it would be more than 16 ar full grottos; well beyond the 14.5 max as discussed before. Thoughts?
   / John Deere 318 voltage regulator #23
Definitely too much voltage. Time to replace the regulator/rectifier.
Thanks! It's on its way. Even though it wasn't at full throttle, that's an accurate assessment?
   / John Deere 318 voltage regulator #25
YES! Definately way too much voltage, as suspected. Do not run the machine again with out first fixing the over voltage issue. You could end up cooking your new battery too -s and same dangerous issues are still opresent for the new battery at any voltage above 14.5 MAXIMUM.
ALSO, NEVER, EVER ADD ACID to any battery if the individual cells are low on fluid. ONLY ADD WATER, nothing else. The ONLY time a battery has acid added is if it was dry from the factory and came with a container with acid to add at time of first use/delivery. Water was also added to make the cells wet and ready for their first charge to full state of charge. I haven't seen that type of battery situation in over 20 years.
Good to know. I'll have to figure out how to hook up the new regulator. It's got 3 prongs side by side. The current one (original I'm sure) has two side by side with one on top.
   / John Deere 318 voltage regulator #27
<SNIP>
If acid boiled over, you need to take the battery out and clean anywhere acid could go, acid is highly corrosive and if left alone could eat its way threw metal.
I'm not sure of the best way to clean acid, I would thing a heavy Base type cleaner? To neutralize the acid? Idk
BAKING SODA, is what should be used to neutralize battery acid. And water, flush your eyes, hands anywhere acid gets whether it is wet or white powdered acid that has dried out.
Be very careful with liquid acid, if it contacts your eyes or mouth your most likely headed to the ER, it has the potential to burn your skin as well, a non absorbent glove is suggested until the battery is free of exterior acid, a trip to advance to have the battery checked wouldn't be a bad idea also, if it has caps you may have to top off the acid.
*NO, NEVER! DO NOT ADD ACID to an already used lead/acid/wet battery! ONLY add, preferably distilled water to the top of each split ring of individual cells
Good Luck and be careful.
Always remember to disconnect the power(battery) before wiring anything up.
* Trust me on the above; I owned and ran a foreign auto repair and sales facility for over ten years. I was an Interstate Battery dealer too. ACID does NOT get added to already in use batteries.
   / John Deere 318 voltage regulator #28
Do you have a pic of the old regulator? Not sure I've seen one different than this type.
   / John Deere 318 voltage regulator #30
When I was a kid 15+ years ago my dad bought a battery for his mower and he had to add the acid, I haven't seen one since.
Thanks for the correction, I personally have never dealt with one but have seen one or two my dad bought.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
1974 Ford F600 Grain Truck (A55315)
1974 Ford F600...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2007 Toyota Corolla LE Sedan (A55853)
2007 Toyota...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
