John deere 300 hydros
/ John deere 300 hydros #1
Dconk91
barnesville, ga
John Deere 301a
I have a jd 300 with front loader, and box blade, everytime i use to box blade my hydraulics die, but if i take the box blade off i have no issues, i was thinking that my 3 point hitch lift is leaking around the piston in the rockshaft housing, is there a better was to diagnose this?
/ John deere 300 hydros #2
With hyd oil at operating temp,3 pt raised,engine running look in hyd filler hole behind seat for moving/spraying oil. If moving oil is seen then rockshaft valve seals are probably leaking & need replaced.
It was was settled debri behing the pump screen, a little help with a bore scope, and magnet and everything works great now
This is what my 300s trans looks like, it has 3 bolt holes for pressure control valve but does not have the second hole....received_2292755624272644.jpeg
/ John deere 300 hydros #6
Yes your tractor must be below serial number 45199. You can get by without installing pressure control valve or install valve & see what happens. Either way won't cause 3 to operate correctly
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2022 EZ-GO ELITE...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A64557)
2019 Mercedes-Benz...
