Buying Advice John Deere 2520
/ John Deere 2520 #1
Jack Murdock
Stephentown NY
John Deere 2032R
I am considering trading ( or selling outright ) my low hours ( 645 ) very clean JD790 / ags / power beyond/ gear / 419FEL in on a 2520 with 775 hours / hydro / FEL / 54SB snow blower.
I would be interested in thoughts advice etc the 790 I moved snow and brush hogged the field twice a year and used hauling firewood. The very decent and knowledgeable owner of the JD dealership tells me I will love the snowblower and a hydro static transmission.
Thanks in advance.
/ John Deere 2520 #2
I recently traded my 2004 790 (w/ 258 hours) for a 2013 2032R (w/ 59 hours) and am happy with the change.
My 790 had 300 FEL and 60" MMM, the 2032R came with nothing.
But I was able to move my 200CX FEL from my 2320 to the 2032R (w/ correct Loader posts).
I liked that gear shift transmission, but cleaning my steep driveway (1/2 mile long) with the FEL, getting up in age (61), it would be hard on my clutch leg, I do like the twin pedal JD set-up.
/ John Deere 2520 #3
The 2520's are very solid machines, I think it's a great upgrade from your 790.
/ John Deere 2520
Thanks much they have the deposit so its a done deal. It will be my first hydro-static transmission but about my 5th JD in the last 30 years. Do you run turf tires in the woods ? I skid a little firewood. They are adding the power beyond so I can use my hydraulic capstan winch and grapple. How does hydro static perform compared to gears ?
Thanks
/ John Deere 2520 #5
I love my 2008 2520. It has been a very stout, reliable tractor. I too, skid some firewood with mine and love the improved ground clearance over my JD 2305. I have R4 tires so no experience with turfs in the woods … Good luck!
Frank
/ John Deere 2520 #6
Thanks
Turfs are softer and more flexible than R4's, so be careful in the woods-but with care they should do well.
Regarding the hydro tranny, just remember the pedals are not "accelerator" pedals, but rather more like a variable gear ratio pedal, less pedal is a lower gear so when need power don't mash on it-you'll sit there.
/ John Deere 2520 #7
Do not forget there is a reason it has ranges for the transmission. Regardless how lightly you press the pedal it will not pull well in high range like it will in low.
/ John Deere 2520 #8
The hydrostatic requires more power to operate than gears. I have a 2720. I would never go back to gears. It's worth the power reduction. If it spins too much in the woods, use chains.
/ John Deere 2520
thanks all I am anxious to get the 2520 here and the 790 sold. The 790 is still in my neighbors barn until someone shows up with some $$
213089 (A64276)
213089 (A64276)
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
2016 VOLVO A40G OFF ROAD DUMP TRUCK (A65056)
2016 VOLVO A40G...
2017 International WorkStar 7500 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A66736)
2017 International...
2027 . . (A67714)
2027 . . (A67714)
2023 Kubota M5-091D 4WD 92HP Utility Loader Tractor (A66734)
2023 Kubota...
