Buying Advice John Deere 2520
/ John Deere 2520 #1
Jack Murdock
Stephentown NY
John Deere 2032R
I am considering trading ( or selling outright ) my low hours ( 645 ) very clean JD790 / ags / power beyond/ gear / 419FEL in on a 2520 with 775 hours / hydro / FEL / 54SB snow blower.
I would be interested in thoughts advice etc the 790 I moved snow and brush hogged the field twice a year and used hauling firewood. The very decent and knowledgeable owner of the JD dealership tells me I will love the snowblower and a hydro static transmission.
Thanks in advance.
/ John Deere 2520 #2
I recently traded my 2004 790 (w/ 258 hours) for a 2013 2032R (w/ 59 hours) and am happy with the change.
My 790 had 300 FEL and 60" MMM, the 2032R came with nothing.
But I was able to move my 200CX FEL from my 2320 to the 2032R (w/ correct Loader posts).
I liked that gear shift transmission, but cleaning my steep driveway (1/2 mile long) with the FEL, getting up in age (61), it would be hard on my clutch leg, I do like the twin pedal JD set-up.
/ John Deere 2520 #3
The 2520's are very solid machines, I think it's a great upgrade from your 790.
/ John Deere 2520
Thanks much they have the deposit so its a done deal. It will be my first hydro-static transmission but about my 5th JD in the last 30 years. Do you run turf tires in the woods ? I skid a little firewood. They are adding the power beyond so I can use my hydraulic capstan winch and grapple. How does hydro static perform compared to gears ?
Thanks
/ John Deere 2520 #5
I love my 2008 2520. It has been a very stout, reliable tractor. I too, skid some firewood with mine and love the improved ground clearance over my JD 2305. I have R4 tires so no experience with turfs in the woods … Good luck!
Frank
/ John Deere 2520 #6
Thanks
Turfs are softer and more flexible than R4's, so be careful in the woods-but with care they should do well.
Regarding the hydro tranny, just remember the pedals are not "accelerator" pedals, but rather more like a variable gear ratio pedal, less pedal is a lower gear so when need power don't mash on it-you'll sit there.
/ John Deere 2520 #7
Do not forget there is a reason it has ranges for the transmission. Regardless how lightly you press the pedal it will not pull well in high range like it will in low.
/ John Deere 2520 #8
The hydrostatic requires more power to operate than gears. I have a 2720. I would never go back to gears. It's worth the power reduction. If it spins too much in the woods, use chains.
/ John Deere 2520
thanks all I am anxious to get the 2520 here and the 790 sold. The 790 is still in my neighbors barn until someone shows up with some $$
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2025 LandHonor LHR-G209 Anchor Shackle Set (A64194)
2025 LandHonor...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2022 WACKER NEUSON G25 TOWABLE GENERATOR (A63276)
2022 WACKER NEUSON...
