chazdo2
Bronze Member
Battery will not charge. No blown fuses K - 5 relay replaced along with voltage regulator. Alternator or generator has 32 volts AC output. Yellow battery light comes on. I have a new voltage regulator in it. Checked the white wire output was 14 volts! Great right? Ran the tractor for about 5 minutes now its 42 volts DC ! I have the old voltage regulator as well as the new and both show 40 volts DC out! The AC from the generator/alternator is 36 volts AC or 16 to 17 each AC leg to ground. 36 volts AC when measured together. Looks like this voltage regulator **** the bed too? If so what would do it before I buy another? Every schematic I find hasn't got the alternator in it?# I need HELP!!!!!
