John Deere 2006 2520 Compact
/ John Deere 2006 2520 Compact #1
biyou
Does anyone else have a problem with the 3pt arms rubbing the tires when you lift them all the way up? If you have and fixed the problem let me know?
Thanks biyou
/ John Deere 2006 2520 Compact #2
Hi--if you do a search on 2520 and lift arms you will find a ton of info. I believe that JD had a replacement/different set of 3pt lift arms (sometimes replaced under warranty).
Thank you, I'll stop at the John Deere store and check it out.
Thanks biyou
/ John Deere 2006 2520 Compact #4
I believe the replacement arms are the ones that come as original equipment on the 2720.
/ John Deere 2006 2520 Compact #5
your dealer should be able to take care of this for you. i just went throught it with mine they replaced them no questions asked.
F-250 SuperDuty (A63689)
F-250 SuperDuty...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
240 Massey Ferguson Tractor (A61165)
240 Massey...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
Pole / Log Dolly (A62613)
Pole / Log Dolly...
2020 Crown Concrete Mixer (A65579)
2020 Crown...
