John Deere 2006 2520 Compact
   / John Deere 2006 2520 Compact #1
biyou
Does anyone else have a problem with the 3pt arms rubbing the tires when you lift them all the way up? If you have and fixed the problem let me know?
Thanks biyou
   / John Deere 2006 2520 Compact #2
Hi--if you do a search on 2520 and lift arms you will find a ton of info. I believe that JD had a replacement/different set of 3pt lift arms (sometimes replaced under warranty).
Thank you, I'll stop at the John Deere store and check it out.
Thanks biyou
   / John Deere 2006 2520 Compact #4
I believe the replacement arms are the ones that come as original equipment on the 2720.
   / John Deere 2006 2520 Compact #5
your dealer should be able to take care of this for you. i just went throught it with mine they replaced them no questions asked.
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
40' High Cube Four Multi Doors Container (A47477)
40' High Cube Four...
New Holland 57 Rake (A53316)
New Holland 57...
2005 Turtle Mountain 1 Ton Military Portable Power Unit Frame Trailer (A55758)
2005 Turtle...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
