John Deere 2006 2520 Compact
   / John Deere 2006 2520 Compact #1
biyou
Does anyone else have a problem with the 3pt arms rubbing the tires when you lift them all the way up? If you have and fixed the problem let me know?
Thanks biyou
   / John Deere 2006 2520 Compact #2
Hi--if you do a search on 2520 and lift arms you will find a ton of info. I believe that JD had a replacement/different set of 3pt lift arms (sometimes replaced under warranty).
Thank you, I'll stop at the John Deere store and check it out.
Thanks biyou
   / John Deere 2006 2520 Compact #4
I believe the replacement arms are the ones that come as original equipment on the 2720.
   / John Deere 2006 2520 Compact #5
your dealer should be able to take care of this for you. i just went throught it with mine they replaced them no questions asked.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
(APPROX 21) UNUSED LANDHONOR PINS (A54757)
(APPROX 21) UNUSED...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
