John Deere 1120 PTO problem
/ John Deere 1120 PTO problem #1
jdunz
JD2040
Needing some help with a tractor I just bought, pto will not engage with clutch pushed in, supposedly has a new clutch installed, I have tried in every gear, only way is to engage with engine off, but Im afraid that may do damage to starter, there is about 2 of slack in the clutch pedal before it starts to engage clutch, which I think is about right, any help will be gentle appreciated.
7988B93B-E770-43C3-8F48-BBAF9465F35C.jpeg6E7B37C2-A59D-4547-A66D-E92F72DAD286.jpegD2AC5ADF-74C5-4ABD-86E6-20F816C4B66A.jpeg
Also what is the lever for in photo 1 and the purpose of the thing on the dash on the other photo
/ John Deere 1120 PTO problem #3
Welcome to TBN
Lever is for draft control L=load,D=depth L/D is setting in between L & L/D are utilized for plowing with implement on 3 pt all other task should be performed in D. I think to need to lower clutch pedal free travel to 1''. Thing on dash is for spraying starting fluid into after removing both caps for cold starting aid& L/D
