john deere 1050
/ john deere 1050 #1
kybundy
Ferron ut 84523
john deere 1050 8a
on my tractor the bucket is stuck, in the curled down position and when i pull the lever to bring it back the bottom hoses (which are the ones in the middle of the ram) go super hard. how do i fix it.
/ john deere 1050 #2
If you have QD's, reconnect them.
If you have a hyd gage in the FEL IN port, and you see pressure but no cyl movement, then you know the QD is mis-connected.
/ john deere 1050
i failed to mention that it was working. then the curl down lever got stuck and after that then it stop working altogether. could the rams be bad?
/ john deere 1050 #4
Sure the rams could be bad, but there are ways to check the seals.
A pressure gage should help you troubleshoot the hyd system.
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2013 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2013 CATERPILLAR...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
