John Deere 1025r
/ John Deere 1025r #1
Streetcar
Cincinnati ,ohio
John Deere 870
Ordered new tractor
ordered 6’ MMM
4’ aerator
sprayer
loader and backhoe for tractor
/ John Deere 1025r #2
We will all be interested to see how long it takes to get it.
/ John Deere 1025r #3
Well at least you won't need the mower for 5 months or so. :) That's a nice set up congratulations.
/ John Deere 1025r
Plan to use tractor for maintenance task and back up mower for zero turn
/ John Deere 1025r #5
I just got one a couple months ago. Didn't know 72" MMM was an option. I have the 60". I can cut full speed in high range on normal lawn grass without much issue. For such a small tractor it sure does a lot of work! Rear ballast is your friend using the loader. I usually keep my rotary cutter hooked up and it still seems a little light in the back end. You will probably be fine if the backhoe is hoked up. Although be careful as I'm sure a lot of that weight is up high.
I really want to try a 5' rotary cutter on it. I'm sure it would have plenty of power but I'm not sure about keeping the front tires on the ground.
/ John Deere 1025r #6
5" should be no problem at all . . . :LOL:
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
1996 Champion 540P (A64126)
1996 Champion 540P...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
3 Point Trailer Mover (A65640)
3 Point Trailer...
Andy 600 (A64126)
Andy 600 (A64126)
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
