John Deere 1025r
/ John Deere 1025r #1
Streetcar
Cincinnati ,ohio
John Deere 870
Ordered new tractor
ordered 6’ MMM
4’ aerator
sprayer
loader and backhoe for tractor
/ John Deere 1025r #2
We will all be interested to see how long it takes to get it.
/ John Deere 1025r #3
Well at least you won't need the mower for 5 months or so. :) That's a nice set up congratulations.
/ John Deere 1025r
Plan to use tractor for maintenance task and back up mower for zero turn
/ John Deere 1025r #5
I just got one a couple months ago. Didn't know 72" MMM was an option. I have the 60". I can cut full speed in high range on normal lawn grass without much issue. For such a small tractor it sure does a lot of work! Rear ballast is your friend using the loader. I usually keep my rotary cutter hooked up and it still seems a little light in the back end. You will probably be fine if the backhoe is hoked up. Although be careful as I'm sure a lot of that weight is up high.
I really want to try a 5' rotary cutter on it. I'm sure it would have plenty of power but I'm not sure about keeping the front tires on the ground.
/ John Deere 1025r #6
5" should be no problem at all . . . :LOL:
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
