John Deere 1025r
/ John Deere 1025r #1
Streetcar
Cincinnati ,ohio
John Deere 870
Ordered new tractor
ordered 6’ MMM
4’ aerator
sprayer
loader and backhoe for tractor
/ John Deere 1025r #2
We will all be interested to see how long it takes to get it.
/ John Deere 1025r #3
Well at least you won't need the mower for 5 months or so. :) That's a nice set up congratulations.
/ John Deere 1025r
Plan to use tractor for maintenance task and back up mower for zero turn
/ John Deere 1025r #5
I just got one a couple months ago. Didn't know 72" MMM was an option. I have the 60". I can cut full speed in high range on normal lawn grass without much issue. For such a small tractor it sure does a lot of work! Rear ballast is your friend using the loader. I usually keep my rotary cutter hooked up and it still seems a little light in the back end. You will probably be fine if the backhoe is hoked up. Although be careful as I'm sure a lot of that weight is up high.
I really want to try a 5' rotary cutter on it. I'm sure it would have plenty of power but I'm not sure about keeping the front tires on the ground.
/ John Deere 1025r #6
5" should be no problem at all . . . :LOL:
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2006 Ford F450 XL Super Duty Swab Rig (A62679)
2006 Ford F450 XL...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
