JINMA 554 cLUTCH STUCK
/ JINMA 554 cLUTCH STUCK #1
llamontagne1
I have a Jinma 554 that the clutch is stuck. Everything seems to be covered up so I can't see anything. I have to start it in gear to move it. Any suggestions to get it to release?
/ JINMA 554 cLUTCH STUCK #2
Put the tractor in 4wd, 2nd low, start the tractor and once you are moving spike the brake pedal and that should get it free.
Make sure you are in 4wd or you take a chance of breaking the input shaft.
/ JINMA 554 cLUTCH STUCK #3
I am sure Wallace meant to say also you need to have the clutch pedal pushed all the way down before you hit the brake.
/ JINMA 554 cLUTCH STUCK #4
heck.. clutch down, 4wd, breaks locked.. just bumping the starter over multiple times may do it.
soundguy
Craftsman tool box with topper (A64047)
Craftsman tool box...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
120 GALLON WATER TANK (A62131)
120 GALLON WATER...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2013 KUBOTA RTV500 UTV (A62130)
2013 KUBOTA RTV500...
