JINMA 554 cLUTCH STUCK
/ JINMA 554 cLUTCH STUCK #1
llamontagne1
I have a Jinma 554 that the clutch is stuck. Everything seems to be covered up so I can't see anything. I have to start it in gear to move it. Any suggestions to get it to release?
/ JINMA 554 cLUTCH STUCK #2
Put the tractor in 4wd, 2nd low, start the tractor and once you are moving spike the brake pedal and that should get it free.
Make sure you are in 4wd or you take a chance of breaking the input shaft.
/ JINMA 554 cLUTCH STUCK #3
I am sure Wallace meant to say also you need to have the clutch pedal pushed all the way down before you hit the brake.
/ JINMA 554 cLUTCH STUCK #4
heck.. clutch down, 4wd, breaks locked.. just bumping the starter over multiple times may do it.
soundguy
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
