Jinma 354LE idle
   / Jinma 354LE idle #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
I have a new Jinma 354LE that the idle is to low. Engine barely remains running and I have to set the hand throttle for it to idle correctly (around 600 RPM). I have the 3-cylinder Y385 engine, anyone know how to increase the idle?
   / Jinma 354LE idle #2
Well if you have a 354LE it will have a Y395 engine not a Y 385 ?? If you look on the injector pump you will see a idle adjustment screw.it has a lock nut on it.If you move the hand throttle you will see the arm move.Loosen the locknut and using a screwdriver turn the screw in a little at a time until you get it set around 600-700 rpm.
Tommy
Affordable Tractor Sales
   / Jinma 354LE idle
Thanks Tommy! I'll give it a shot!
John Deere 5055E (A53317)
John Deere 5055E...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
BOX BLADE (A58214)
BOX BLADE (A58214)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
