Jinma 354LE idle
   / Jinma 354LE idle #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
I have a new Jinma 354LE that the idle is to low. Engine barely remains running and I have to set the hand throttle for it to idle correctly (around 600 RPM). I have the 3-cylinder Y385 engine, anyone know how to increase the idle?
   / Jinma 354LE idle #2
Well if you have a 354LE it will have a Y395 engine not a Y 385 ?? If you look on the injector pump you will see a idle adjustment screw.it has a lock nut on it.If you move the hand throttle you will see the arm move.Loosen the locknut and using a screwdriver turn the screw in a little at a time until you get it set around 600-700 rpm.
Tommy
Affordable Tractor Sales
   / Jinma 354LE idle
Thanks Tommy! I'll give it a shot!
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
