Jinma 354LE idle
   / Jinma 354LE idle #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
I have a new Jinma 354LE that the idle is to low. Engine barely remains running and I have to set the hand throttle for it to idle correctly (around 600 RPM). I have the 3-cylinder Y385 engine, anyone know how to increase the idle?
   / Jinma 354LE idle #2
Well if you have a 354LE it will have a Y395 engine not a Y 385 ?? If you look on the injector pump you will see a idle adjustment screw.it has a lock nut on it.If you move the hand throttle you will see the arm move.Loosen the locknut and using a screwdriver turn the screw in a little at a time until you get it set around 600-700 rpm.
Tommy
Affordable Tractor Sales
   / Jinma 354LE idle
Thanks Tommy! I'll give it a shot!
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
