Jinma 354LE idle
   / Jinma 354LE idle #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
I have a new Jinma 354LE that the idle is to low. Engine barely remains running and I have to set the hand throttle for it to idle correctly (around 600 RPM). I have the 3-cylinder Y385 engine, anyone know how to increase the idle?
   / Jinma 354LE idle #2
Well if you have a 354LE it will have a Y395 engine not a Y 385 ?? If you look on the injector pump you will see a idle adjustment screw.it has a lock nut on it.If you move the hand throttle you will see the arm move.Loosen the locknut and using a screwdriver turn the screw in a little at a time until you get it set around 600-700 rpm.
Tommy
Affordable Tractor Sales
   / Jinma 354LE idle
Thanks Tommy! I'll give it a shot!
2009 GMC Sierra Pickup Truck, VIN # 1GTEC14X29Z187521 (A57453)
2009 GMC Sierra...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A57453)
2007 Hino 268...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59575)
2018 KAUFMAN 44 FT...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
10ft Fork Extensions (A56860)
10ft Fork...
