Jimna 284 Timing
/ Jimna 284 Timing #1
AndyZ
I have been trying to time a new injector pump, I have set it up as instructed but it only starts for a few minutes and stalls, i have never timed a ijector pump like this and I am wondering if I am doing it right,does anyone have any info that could help. I have timing marks on front crank pulley but no marks on flywheel.
/ Jimna 284 Timing #3
Sounds like to me you have the check valve in the wrong spot.There is a hollow bolt on the front side and backside of the injector pump that holds the fuel lines on, the bolt in the front should have a check valve in the center of that bolt, if you find that bolt is on the backside of the pump switch those 2- bolts around .How did you set your timing ? I guess you did not buy the pump from us ?
Tommy
Affordable Tractor Sales
" Your Jinma Parts Superstore "
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
(UNUSED) HARDEE 28 BLADE DISC HARROW (A64278)
(UNUSED) HARDEE 28...
2022 EZ-GO ELITE...
More info coming soon. (A64557)
More info coming...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
