jima backhoe hydro problem
/ jima backhoe hydro problem #1
intheground
jinma 284
hi guys, I have a jima lw-6 backhoe on a jima 284 tractor. while using it today after about 1/2 hour of use the bh seemed to lack the power it normally has and the hydros slowed down. after about an hour it had no power and the hydro just about worked. checked the fluid and it was very hot and airated. drained and change all the fluid, cleaned the filter thinking there might have been water in the hydro fluid because of all the rain we have had. went back to work and it was fine problem solved right.. wrong, after about a 1/2 hour same thing. fluid very hot foamy and the hydro just about worked. check for leaks could not find any thinking it was sucking air somewhere but all looked fine. using the pto and that itself is very very hot. could it be that it is cloged up and not putting out enough fluid? I don't know much about hydraulics so could really use some direction.
thanking you guys in advance..
/ jima backhoe hydro problem #2
Possible one of the relief valves is sticking, causing the fluid to overheat. Is it making a loud squealing noise?
If the fluid is foamy, then there is a leak on the return/suction side of the system-hard to find because you will not see any external leaks.
This is a separate system from the tractor? You are using a PTO powered pump? Is there a filter? they are often the cause of leaks.
no loud squealing, but can here a straining sound in the pump when I engage bh. fliud is foamy and yes i'm using the pto pump there is a filter inside the tank which I checked and cleaned today when I changed the fluid.
/ jima backhoe hydro problem #4
Sounds definitely like a return side leak...
will change the gasket on the filter and the o ring on the return side hose tomorrow is thier any other place it could be?
/ jima backhoe hydro problem #6
I put a penny on the suction line/side...;) is there a suction strainer in the tank?
Edit
You are right Kenny, suction side dont show oil leaks.....still worth a check up, since oil shows foam/air....and how about shaft seal on pump?
/ jima backhoe hydro problem #7
Had the jw3 did the exact same thing ended up being a bad seal in the adjustment valve. Took more time to find it then replace, tiny little bugger tucked up inside.
/ jima backhoe hydro problem #8
I have seen / found some problems with / in the pressure relief assy.
Ronald
Ranch Hand Supply
/ jima backhoe hydro problem #9
I vote for the over pressure scenario also. Pressure = heat. Get a metric to NPT(18X1.5MM to 1/4NPT I believe) adapter and a gauge. Remove the metric to ORFS adapter on one of hte working ports and screw this assembly into that port to see what pressure it is actually releiving at... Lot of guessing and unknowns untill you actually know what all the variables are.
That pump should be as quiet as the pump up on the front of the tractor. I have this same backhoe, and the pump was noisy since new. The fluid returning to the resovoir does so thru the center of a banjo bolt on the left side of the tank. The center of that bolt is about 1/4" in diameter so the fluid returns as a high velocity straight stream. This shooting into the fluid in the resovoir injects bubbles into it and this whole areated mess rolls down past the intake strainer. I redid my return line so the fluid enters the tank slower and now my pump dosn't make a sound...
/ jima backhoe hydro problem #10
Of course pressure creates heat when there is air in the oil....compressing air creates heat!! and then the hot air heats up the oil....but how would air get into a pressureized line??? It must come from a line with pressure lower than atmospheric pressure...the suction line!!!
I still bet on the suction side for the air problem......and I agree about the pressurized side for the heat problem....;)
/ jima backhoe hydro problem #11
Hi, I have a Jinma 254 and recently bought a LW6 back hoe.
I'm struggling to get them attached without the pump turning with the PTO of the tractor.
Please could you send me pictures of how you sorted the attachment of the backhoe pump to the tractor out.
Much appreciated.
Ivo
/ jima backhoe hydro problem #12
The factory pumps that I have seen that come with the backhoes attaches to the tractor above the PTO shaft.
You are welcome to email me some pictures of your pump set up if you choose.
You can use any of the email contacts on my web site; Jinma Dealer, Wood Chipper , Compact Jinma Tractors
I may have some pictures ???
Ronald
Ranch Hand Supply
Aluminum Deer (A65583)
2008 COTTRELL CAR HAULER (A65643)
2008 COTTRELL CAR...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A67147)
2016 INTERNATIONAL...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Cattle Feeder (A65640)
