JIC PLUG AND CAP SET
/ JIC PLUG AND CAP SET #1
Jeff Lary
Platinum Member
Hartland Maine
Kubota L2950
I have a 1995 Kubota L2950 30 hp tractor. I would like to get a few plugs and caps. I am thinking the lines to cap and plug will be 1/4" and 3/8" does that sound right? I see most all kits have much larger caps and plugs in them also, I cannot see me ever needing the large ones.
First question, am I right about my hose sizes mainly being 1/4 and 3/8 sizes?
Second question, should I just get some of each of those two sizes or get a kit that has other sizes as well?
Third and last question, does anyone have a kit that they would recommend me getting for this size tractor?
Thanks Jeff
/ JIC PLUG AND CAP SET #2
Look up “Kenny’s Bolt On Hooks”. Under hydraulic parts he has caps and plugs. The ones on my JD wouldn’t stay in place so I got a set from Kenny. My end loader had color coded ones and I had a bunch of colored zip ties I attached to each hose to keep them straight.
/ JIC PLUG AND CAP SET #6
Thanks Jeff
What are you trying to cap off? I assume you're talking about connections on the loader?
The most common size will be -6 and -8 ( 3/8 and 1/2).
You might use some -4 (1/4) for steering lines but I'm not familiar with your model.
There might also be some -10 for feed lines.
I have seen some plug/ cap sets of one specific size and a variety, but the variety sets will usually have some sized you probably won't need.
Sent from my SM-S921U using TractorByNet mobile app
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
QA 72" Grapple Attachment (A64126)
QA 72" Grapple...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
ROAD GEAR ALUMINUM HEADACHE RACK (A64277)
ROAD GEAR ALUMINUM...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
