JIC PLUG AND CAP SET
/ JIC PLUG AND CAP SET #1
Jeff Lary
Platinum Member
Hartland Maine
Kubota L2950
I have a 1995 Kubota L2950 30 hp tractor. I would like to get a few plugs and caps. I am thinking the lines to cap and plug will be 1/4" and 3/8" does that sound right? I see most all kits have much larger caps and plugs in them also, I cannot see me ever needing the large ones.
First question, am I right about my hose sizes mainly being 1/4 and 3/8 sizes?
Second question, should I just get some of each of those two sizes or get a kit that has other sizes as well?
Third and last question, does anyone have a kit that they would recommend me getting for this size tractor?
Thanks Jeff
/ JIC PLUG AND CAP SET #2
Look up “Kenny’s Bolt On Hooks”. Under hydraulic parts he has caps and plugs. The ones on my JD wouldn’t stay in place so I got a set from Kenny. My end loader had color coded ones and I had a bunch of colored zip ties I attached to each hose to keep them straight.
/ JIC PLUG AND CAP SET #6
Thanks Jeff
What are you trying to cap off? I assume you're talking about connections on the loader?
The most common size will be -6 and -8 ( 3/8 and 1/2).
You might use some -4 (1/4) for steering lines but I'm not familiar with your model.
There might also be some -10 for feed lines.
I have seen some plug/ cap sets of one specific size and a variety, but the variety sets will usually have some sized you probably won't need.
Sent from my SM-S921U using TractorByNet mobile app
KBH Tender Trailer (A63689)
KBH Tender Trailer...
65' Extension Cord Reel (A66408)
65' Extension Cord...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
