JD750 MFWD
/ JD750 MFWD #21
Well it appears that I can order all of the parts I will need, jdparts seems reasonable, however I do not need to go through a dealer to order parts, I can do that myself!! John Deere needs to create a Amazon like website for its parts center. If I wait on my dealer, my tractor will be down for weeks.
Try Green Farm Parts: The John Deere Parts Discount Store Use coupon code FIREWORK for 10% off if your spending over $150. Good until 7-05-15 Plus they sell for less than most JD dealers before the discount.
/ JD750 MFWD
Thanks, that lowered the repair bill by 50%. I need to look over the front axle to see if the seal is bad or if the swivel joint is just leaking, as the entire area is covered in grease. perhaps I will do that tomorrow if it stops raining long enough.
/ JD750 MFWD
Here is the parts list for future reference.
Code Item Qty Price Grand Total
R26552 John Deere Ball R26552 12 $1.36 $16.32
CH14966 John Deere Shoe CH14966 1 $11.80 $11.80
CH13522 John Deere Packing CH13522 1 $3.84 $3.84
CH14633 John Deere Seal CH14633 1 $9.01 $9.01
CH14583 John Deere Packing CH14583 1 $0.93 $0.93
CH11571 John Deere Packing CH11571 2 $2.63 $5.26
M801916 John Deere Boot M801916 2 $3.67 $7.34
11M7087 John Deere Cotter Pin 11M7087 1 $0.32 $0.32
Subtotal: $54.82
Tax: $0.00
Shipping Cost: $11.09
Grand Total: $65.91
/ JD750 MFWD
Spent some more time on the tractor today, once you get into things you typically find more issues.
Two of the bearings are suspect, one had metal flakes around the snap ring and the other one is sticky, those to be replaced.
The lands on the pinion gear look great, I was suspecting to see noticeable wear marks but to my surprise nothing.
The tang that holds one of the driveshaft covers had snapped off, that part will be fab'd and TIG welded.
The seal was bad and will be replaced as well, which leads me to placing another order for bearings and a few more seals/packings.
Images: - - Album on Imgur
/ JD750 MFWD
Driveshaft cover finally patch welded.
/ JD750 MFWD
I apologize that I did not take snap any pics of the completion, but all went well with the repair.
The driveshaft is kinda a pin in the *** to install with the loss ball bearings, but finally got it together.
Did a few tests and and my 4-wheel drive works now and I can drag a box blade up the hill no problem.
I would like to thank everyone for their assistance.
D.
/ JD750 MFWD
One thing I will add, is the rubber boots that slide over the ball bearing couplings. The Deere parts calls for using wire tires to secure both ends, what I did was use a tie on one end and some silicone fusing tape on the other end as the ball bearings seem to jump out for whatever reason.
If anyone is interested I will snap a picture.
CAT 272D3 SKID STEER (A65053)
CAT 272D3 SKID...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
