JD5300
   / JD5300 #1
plumbstraight
Washington state and Ak
5300 John deere,53 harry ferguson, ck20 kioti, 135 ferguson, 350jd dozer, k40 kubota excavator
My tractor has just over 3000hrs on it. Last spring the hydraulics shut down. I pulled the screen in the bottom of the transmission and found it plugged with very fine black particles. I cleaned it up, changed the main filter and put in new oil. Couple of days ago it started in giving me some issues like the hydraulics were starving. I pulled the screen again and found it to have more of this material on it although not as bad. I put my finger in the filter hole and was able to get some fiber pieces out that were laying on the bottom of the case. Only thing I can think they might be part of is the hyd forward/reverse clutches.
Looks like a tear down now. Anyone else had any issues like this? This tractor has been torn down 3 times under warrantee. Will do this one myself.
   / JD5300 #3
It the transmission is working fine, I would suspect brakes as Tx Jim said.
   / JD5300
Thank you for the input, never thought about brakes. Will take a look at the circumference of the different systems. As I have a small piece it gives me a small idea at how big the diameter of the discs. Will be a while before I get serious about getting into it. Will be gone till after the new year.
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
Toro Z Master Mower (A50324)
Toro Z Master...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
