JD500b starting problems.
/ JD500b starting problems. #1
PaulJD500b
JD 500b backhoe
I have a JD500b diesel backhoe. It has starting issues and I am losing my mind. Problem came on all of a sudden. It just clicked at first, wouldn't even start with a jump.I replaced the starter relay on the firewall. It still just clicked, but then none of the dash lights would come on and there was intermittent power to the ignition switch, but the machine would start with a jump. Now it won't start at all. Tested the batteries and they would drop to 6v when the key was turned, so replaced the batteries. Then when I tried to connect the new batteries the starter kicked when I attached the positive cable. Figured solenoid or starter, replaced the solenoid, no change. Thought maybe ignition switch, took it out, no change. What is going on?
/ JD500b starting problems. #2
Welcome to this forum.
Are you positive that you have battery cables are attached correctly?
I suggest to clean/tighten battery negative cable where it attaches to tractor frame.
Check battery cables under insulation for corrosion.
If batteries voltage won't go over 12 volts then I'll suggest to have new batteries load tested
/ JD500b starting problems. #3
Agree with Tx Jim 100% for next step forward. Keep us posted how it works out.
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
