JD500b starting problems.
/ JD500b starting problems. #1
PaulJD500b
JD 500b backhoe
I have a JD500b diesel backhoe. It has starting issues and I am losing my mind. Problem came on all of a sudden. It just clicked at first, wouldn't even start with a jump.I replaced the starter relay on the firewall. It still just clicked, but then none of the dash lights would come on and there was intermittent power to the ignition switch, but the machine would start with a jump. Now it won't start at all. Tested the batteries and they would drop to 6v when the key was turned, so replaced the batteries. Then when I tried to connect the new batteries the starter kicked when I attached the positive cable. Figured solenoid or starter, replaced the solenoid, no change. Thought maybe ignition switch, took it out, no change. What is going on?
/ JD500b starting problems. #2
Welcome to this forum.
Are you positive that you have battery cables are attached correctly?
I suggest to clean/tighten battery negative cable where it attaches to tractor frame.
Check battery cables under insulation for corrosion.
If batteries voltage won't go over 12 volts then I'll suggest to have new batteries load tested
/ JD500b starting problems. #3
Agree with Tx Jim 100% for next step forward. Keep us posted how it works out.
121A (A63745)
121A (A63745)
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2022 EZ-GO ELITE...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
