JD4600 hydraulic problem (HELP)
/ JD4600 hydraulic problem (HELP)
MD3, if you mean the self adjust rate for how fast/slow the 3pt arms react to hydrolic control, that is beneath the driver's seat.
No that is not what I meant to relay. I should try to explain myself a little better. Say the tractor is running and a Bush Hog is mounted on the 3 point. Put the tractor in park and raise the Bush Hog. Now get off of the tractor and watch the Bush Hog start to drift slowly downward maybe about 1? Now I hear a vvvvvp and the Bush Hog raises back up that 1 it lost.
Yep, I come across White Oak Road daily. Turn left at Manor Road.
Are you the gent with the Deere (with backhoe) that was setting at the end of the drive for about 3 weeks last winter? I thought it was a 4400, but I could be mistaken.
In the hollow with the fake log house. You will not see it there this winter. I built a (wood/tractor)carport this year. Now she will stay dry.
/ JD4600 hydraulic problem (HELP) #23
With the box blade on, it drifts down about 1-3" then corrects. (no sound) But I will take a closer look at it this weekend to make sure. These observations are from my tractor seat.
UNUSED SWICT 66" BUCKET (A64280)
UNUSED SWICT 66"...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A61572)
2016 New Holland...
2019 Deere 35G (A64126)
2019 Deere 35G...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2025 Auger Drill Bit Skid Steer Attachment (A61572)
2025 Auger Drill...
