JD4500 Wont Start
/ JD4500 Wont Start #1
AZBrad99
John Deere 4500
I have a 4500 with 1900 hours that would start or take a jump. Replaced battery and the thing fired right up and ran for 10 minutes while I put all the body parts back on. Turned it off for a few minutes to fuel it up and now can't get to turn over.... Unit is in neutral and I have power - but the unit will not turn over. Gets lots of clicking in the engine bay /console - but can't figure out. Pulled and check all regular fuses. Any thoughts?
/ JD4500 Wont Start #2
Welcome to TBN
I suggest to clean/tighten battery ground cable where it attaches to tractor frame.
/ JD4500 Wont Start #3
also check any relays in the starter circuit. Perhaps the relay is not pulling in fully, providing the proper path to pull in the starter solenoid. Do you have a wiring diagram?
Is there something loading the battery and discharging it? with Key off, there should be little to no draw from the battery.
Woods PRD7200 6' Finishing Mower (A66408)
Woods PRD7200 6'...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Pull Behind Sprayer (A65640)
Pull Behind...
