JD4500 Wont Start
/ JD4500 Wont Start #1
AZBrad99
John Deere 4500
I have a 4500 with 1900 hours that would start or take a jump. Replaced battery and the thing fired right up and ran for 10 minutes while I put all the body parts back on. Turned it off for a few minutes to fuel it up and now can't get to turn over.... Unit is in neutral and I have power - but the unit will not turn over. Gets lots of clicking in the engine bay /console - but can't figure out. Pulled and check all regular fuses. Any thoughts?
/ JD4500 Wont Start #2
Welcome to TBN
I suggest to clean/tighten battery ground cable where it attaches to tractor frame.
/ JD4500 Wont Start #3
also check any relays in the starter circuit. Perhaps the relay is not pulling in fully, providing the proper path to pull in the starter solenoid. Do you have a wiring diagram?
Is there something loading the battery and discharging it? with Key off, there should be little to no draw from the battery.
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
Butler MFG Water Tanker (A63689)
Butler MFG Water...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2014 Freightliner M2 106 Water Truck, VIN # 1FVACXDTXEHFU5910 (A65563)
2014 Freightliner...
