JD4100 Quick Hitch Dimensions
/ JD4100 Quick Hitch Dimensions #1
HD4010
Cannonsburg Michigan
Hi,
This might sound like an odd request but I wonder if there is anyone what can tell me the approximate dimensions for the quick hitch for the 4100. I'm looking at buying one of the net and want to get estimated shipping costs but need dimensions.
What is the approximate overall:
Width
Length
Overall height
Height in front where implements attach
Length of the upright piece where that attached to tractor.
I'm thinking if the pin was removed for the hydraulic cylinder and the pin that connects tractor interface to the implement interface it might be cheaper to ship both parts separately vs the whole thing together as it seems like shipper prices are more dependant on volume than weight.
Thanks in advance for any help that may be offered.
HD
/ JD4100 Quick Hitch Dimensions #2
I am a little confused:confused:
Are you looking for something for the FEL or the 3PH? If it's for the loader, then what isn't the JD QA system doing for you?
If it's for the 3PH, then look HERE
Hi,
I`m referring to the front quick hitch that you would use with a front snow blade, snowblower, etc.
Regards,
HD
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
Unused 2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2021 NM...
