JD300 backhoe leaking help
/ JD300 backhoe leaking help #1
swmich
scotts, mi
case sc
My backhoe is leaking hydraulic fluid from the cylinder nearest the bucket. Picture shows where its leaking. I have someone that is familiar with taking these apart and able to do the fix but I went to the JD dealer and they said there are no aftermarket rebuild kits or gaskets available for this cylinder. They said my only option from them is buying a replacement cylinder for $2500. Any help on where I can get a new seal for this? Thanks for any help!!
/ JD300 backhoe leaking help #2
Welcome to TBN
How about giving us some model numbers for the hoe? Should be a tag on it somewhere that will identify what it is. We will try to help.
Model of the tractor might help too, but the hoe is most important.
/ JD300 backhoe leaking help #3
There are businesses that specialize in rebuilding hydraulic cylinders. Find one locally. Remove cylinder, they fix it for you, you put it back in, leak gone.
Alternatively, find a new aftermarket cylinder and just replace it. I have a JD model 48 backhoe and have done that twice with cylinders that I have screwed up. Mine is much smaller than yours, but the principle is the same. I picked mine up from Magister Hydraulics. I've been very happy with them. JD wanted $1500 for a replacement cylinder. Picked up a compatible one from Magister for $300. However a perfect fit is nearly impossible, so some adaptation will probably be needed.
Its a john deere 300 series tractor and loader i think? Serial number on loader is SNE 0092001595U. Serial number on tractor is SNT 4W3D 029793T.
/ JD300 backhoe leaking help #5
Remove it and take it to a hydraulic shop. They will rebuild it and it shouldn't cost a lot either.
/ JD300 backhoe leaking help #6
Let's try that again.
What is the part # that the dealer had for that cylinder that they would/could only replace?
JD parts for the 9200 backhoe (may not be the correct one)
Maybe just need the packing?
Or the seal?
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
KING 4R CHISEL RIPPER BEDDER (A63291)
KING 4R CHISEL...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
