JD300 backhoe leaking help
/ JD300 backhoe leaking help #1
swmich
scotts, mi
case sc
My backhoe is leaking hydraulic fluid from the cylinder nearest the bucket. Picture shows where its leaking. I have someone that is familiar with taking these apart and able to do the fix but I went to the JD dealer and they said there are no aftermarket rebuild kits or gaskets available for this cylinder. They said my only option from them is buying a replacement cylinder for $2500. Any help on where I can get a new seal for this? Thanks for any help!!
/ JD300 backhoe leaking help #2
Welcome to TBN
How about giving us some model numbers for the hoe? Should be a tag on it somewhere that will identify what it is. We will try to help.
Model of the tractor might help too, but the hoe is most important.
/ JD300 backhoe leaking help #3
There are businesses that specialize in rebuilding hydraulic cylinders. Find one locally. Remove cylinder, they fix it for you, you put it back in, leak gone.
Alternatively, find a new aftermarket cylinder and just replace it. I have a JD model 48 backhoe and have done that twice with cylinders that I have screwed up. Mine is much smaller than yours, but the principle is the same. I picked mine up from Magister Hydraulics. I've been very happy with them. JD wanted $1500 for a replacement cylinder. Picked up a compatible one from Magister for $300. However a perfect fit is nearly impossible, so some adaptation will probably be needed.
Its a john deere 300 series tractor and loader i think? Serial number on loader is SNE 0092001595U. Serial number on tractor is SNT 4W3D 029793T.
/ JD300 backhoe leaking help #5
Remove it and take it to a hydraulic shop. They will rebuild it and it shouldn't cost a lot either.
/ JD300 backhoe leaking help #6
Let's try that again.
What is the part # that the dealer had for that cylinder that they would/could only replace?
JD parts for the 9200 backhoe (may not be the correct one)
Maybe just need the packing?
Or the seal?
