JD2640 Hi/Lo Range
/ JD2640 Hi/Lo Range #1
LHughes
I have a JD2640 that is stuck in low range. Has anyone else had this problem?
/ JD2640 Hi/Lo Range #2
Do you mean the left shift lever between your legs? or the shift lever to the left of the steering wheel on the dash? If it is the left lever between your legs/ you will need to remove a snap ring securing the lever that is under the rubber boot. Pull the shift lever out and then reach down into the hole with a long screwdriver to align the 2 shift rails into neutral. Then reinstall the lever and all should work again. If it keeps getting jammed, then one or both of the internal shift rails may need to be replaced.
It is the lever between your legs. Thank you, for your help. I will try that tonight.
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
Walnut Slabs (A65640)
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Hedge Posts (A65640)
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
