JD2640 Hi/Lo Range
   / JD2640 Hi/Lo Range #1
LHughes
I have a JD2640 that is stuck in low range. Has anyone else had this problem?
   / JD2640 Hi/Lo Range #2
Do you mean the left shift lever between your legs? or the shift lever to the left of the steering wheel on the dash? If it is the left lever between your legs/ you will need to remove a snap ring securing the lever that is under the rubber boot. Pull the shift lever out and then reach down into the hole with a long screwdriver to align the 2 shift rails into neutral. Then reinstall the lever and all should work again. If it keeps getting jammed, then one or both of the internal shift rails may need to be replaced.
It is the lever between your legs. Thank you, for your help. I will try that tonight.
   / JD2640 Hi/Lo Range #5
Great! Glad to hear you are back running.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
(INOP) 2018 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A51406)
(INOP) 2018...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2017 Jaguar F-Pace SUV (A55758)
2017 Jaguar F-Pace...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
