JD2640 Hi/Lo Range
/ JD2640 Hi/Lo Range #1
LHughes
I have a JD2640 that is stuck in low range. Has anyone else had this problem?
/ JD2640 Hi/Lo Range #2
Do you mean the left shift lever between your legs? or the shift lever to the left of the steering wheel on the dash? If it is the left lever between your legs/ you will need to remove a snap ring securing the lever that is under the rubber boot. Pull the shift lever out and then reach down into the hole with a long screwdriver to align the 2 shift rails into neutral. Then reinstall the lever and all should work again. If it keeps getting jammed, then one or both of the internal shift rails may need to be replaced.
It is the lever between your legs. Thank you, for your help. I will try that tonight.
2014 DODGE 5500 SERVICE TRUCK (A67714)
2014 DODGE 5500...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2000 CATERPILLAR 322BL EXCAVATOR (A65053)
2000 CATERPILLAR...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
