JD2640 Hi/Lo Range
   / JD2640 Hi/Lo Range #1
LHughes
I have a JD2640 that is stuck in low range. Has anyone else had this problem?
   / JD2640 Hi/Lo Range #2
Do you mean the left shift lever between your legs? or the shift lever to the left of the steering wheel on the dash? If it is the left lever between your legs/ you will need to remove a snap ring securing the lever that is under the rubber boot. Pull the shift lever out and then reach down into the hole with a long screwdriver to align the 2 shift rails into neutral. Then reinstall the lever and all should work again. If it keeps getting jammed, then one or both of the internal shift rails may need to be replaced.
It is the lever between your legs. Thank you, for your help. I will try that tonight.
   / JD2640 Hi/Lo Range #5
Great! Glad to hear you are back running.
Chery Single Portable Toilet (A44502)
Chery Single...
John Deere Gator HPX615E 4x4 Utility Cart (A44572)
John Deere Gator...
2016 Ford F-150 Crew Cab Pickup Truck (A44572)
2016 Ford F-150...
2021 VERMEER S925TX MINI SKIDSTEER (A45046)
2021 VERMEER...
2013 BOBCAT 5175 (A45046)
2013 BOBCAT 5175...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
