JD2010 Inj. pump timing
/ JD2010 Inj. pump timing #1
Anonymous Poster
Epic Contributor
Does anyone have an injector pump timing proceedure including the oil pump position for a JD2010? I have an I&T manual, which is totally inaccurate in many respects including this one. rosemeadoil@discoverycoast.net
/ JD2010 Inj. pump timing #2
Maybe you'll get a specific answer. This one is generic. On many tractors, injector pump timing is done by matching up marks on the crankshaft gear and pump drive gear. It's like timing belts on cars. It's a gross adjustment of getting the right gear teeth meshed rather a fine-tuning. The gears are keyed, so the orientation of the gear on each shaft is guaranteed, and just matching up the marks correctly times the pump. The adjustment may be simple, but substantial tear down is required since the timing gear cover on the front of the engine has to be removed.
On the other hand, the spill time adjustment, which often is associated with pump timing, is a fine adjustment. It is fairly straightforward, but more complex.
It strikes me that pump timing, itself, is simple enough that a dealer's shop manager may be willing to describe it to you. However, you should consider yourself lucky if they'd also describe the spill time adjustment.
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
