JD quick tach?
/ JD quick tach? #2
/ JD quick tach?
Thanks but nothing definitive there, the drawings are gone.
/ JD quick tach? #5
Don't you have a bucket or forks that you can measure ?
It's only width and height numbers that you need. There may be a consideration for the angle of the mounting and the bottom attachment may need to be spaced away from the grapple frame, but this is more important with a bucket. If you don't check this you may not have much "roll back" at ground level for carrying. The other concern is "dumping" with the loader high as in loading a truck, it might not dump enough raised.
I suggest copying the factory angle for the best roll back and dump angles.
/ JD quick tach?
I ended up going and picking up his bucket to make sure I had everything correct, no room for error on the pins.
Thanks everyone!
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2011 TRAIL KING TK70MG-523- 52' LOWBOY TRAILER (A65054)
2011 TRAIL KING...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
1987 CAT D8N (A68134)
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
