JD quick tach?
/ JD quick tach? #2
/ JD quick tach?
Thanks but nothing definitive there, the drawings are gone.
/ JD quick tach? #5
Don't you have a bucket or forks that you can measure ?
It's only width and height numbers that you need. There may be a consideration for the angle of the mounting and the bottom attachment may need to be spaced away from the grapple frame, but this is more important with a bucket. If you don't check this you may not have much "roll back" at ground level for carrying. The other concern is "dumping" with the loader high as in loading a truck, it might not dump enough raised.
I suggest copying the factory angle for the best roll back and dump angles.
/ JD quick tach?
I ended up going and picking up his bucket to make sure I had everything correct, no room for error on the pins.
Thanks everyone!
2018 Chevrolet Equinox SUV (A66738)
2018 Chevrolet...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2019 Kubota RTV X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota RTV...
THUNDER CREEK FUEL TRAILER (A67714)
THUNDER CREEK FUEL...
PALLET OF RAMPS (A68842)
PALLET OF RAMPS...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
