JD quick tach?
/ JD quick tach? #2
/ JD quick tach?
Thanks but nothing definitive there, the drawings are gone.
/ JD quick tach? #5
Don't you have a bucket or forks that you can measure ?
It's only width and height numbers that you need. There may be a consideration for the angle of the mounting and the bottom attachment may need to be spaced away from the grapple frame, but this is more important with a bucket. If you don't check this you may not have much "roll back" at ground level for carrying. The other concern is "dumping" with the loader high as in loading a truck, it might not dump enough raised.
I suggest copying the factory angle for the best roll back and dump angles.
/ JD quick tach?
I ended up going and picking up his bucket to make sure I had everything correct, no room for error on the pins.
Thanks everyone!
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
2019 Nissan Versa Sedan (A66738)
2019 Nissan Versa...
Steiner 60in Fairway Mower Tractor Attachment (A64553)
Steiner 60in...
JOHN DEERE 310SL BACKHOE LOADER (A67714)
JOHN DEERE 310SL...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
More info coming soon. (A64557)
More info coming...
