JD quick tach?
/ JD quick tach? #2
/ JD quick tach?
Thanks but nothing definitive there, the drawings are gone.
/ JD quick tach? #5
Don't you have a bucket or forks that you can measure ?
It's only width and height numbers that you need. There may be a consideration for the angle of the mounting and the bottom attachment may need to be spaced away from the grapple frame, but this is more important with a bucket. If you don't check this you may not have much "roll back" at ground level for carrying. The other concern is "dumping" with the loader high as in loading a truck, it might not dump enough raised.
I suggest copying the factory angle for the best roll back and dump angles.
/ JD quick tach?
I ended up going and picking up his bucket to make sure I had everything correct, no room for error on the pins.
Thanks everyone!
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
Trailking Detach Semi Trailer (A66285)
Trailking Detach...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
