JD oil pressure problems
/ JD oil pressure problems #1
bugzey
how much oil presure should a 3020 have at idle ours has ) and has a low rpm knock I replaced the rod bearings but still has the knock
/ JD oil pressure problems #3
Howdy! welcome to the forum! :thumbsup:
Chek out the John owning operationg section.... Those guys can really help.. There is this one guy over there named Dcyrilc... hit him up for sure.. he likes oil problems!!!!
/ JD oil pressure problems #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the John Deere Owning/Operating Forum. You'll get a better response there. ;)
/ JD oil pressure problems #5
Did you check the bearing clearance before and after with plasti-gage?
by ) pressure, did you mean 0?
/ JD oil pressure problems #6
By "Low RPM"...how low is that? Diesels aren't fond of low RPM (except for shipboard diesels...but they'll built for it). Low RPM can result in the bearings pounding.
How are you measuring the oil pressure? And, is it within range at operating RPM and temperature?
I guess the first question should have been "Is this a diesel? Gasoline? LP?"
2620 (A65055)
2620 (A65055)
POLY WATERING TROUGH & SUCTION HOSE (A64278)
POLY WATERING...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2005 Ford F-150 Ext Cab Pickup Truck (A64556)
2005 Ford F-150...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
