JD oil pressure problems
/ JD oil pressure problems #1
bugzey
how much oil presure should a 3020 have at idle ours has ) and has a low rpm knock I replaced the rod bearings but still has the knock
/ JD oil pressure problems #3
Howdy! welcome to the forum! :thumbsup:
Chek out the John owning operationg section.... Those guys can really help.. There is this one guy over there named Dcyrilc... hit him up for sure.. he likes oil problems!!!!
/ JD oil pressure problems #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the John Deere Owning/Operating Forum. You'll get a better response there. ;)
/ JD oil pressure problems #5
Did you check the bearing clearance before and after with plasti-gage?
by ) pressure, did you mean 0?
/ JD oil pressure problems #6
By "Low RPM"...how low is that? Diesels aren't fond of low RPM (except for shipboard diesels...but they'll built for it). Low RPM can result in the bearings pounding.
How are you measuring the oil pressure? And, is it within range at operating RPM and temperature?
I guess the first question should have been "Is this a diesel? Gasoline? LP?"
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2005 MACK CXN613...
2001 John Deere 6210 (A60462)
2001 John Deere...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
